If the power adapter isn't working, install a new one! This guide shows you how to change out an old power adapter that may not be working right.
Note: This guide involves soldering and should not be done by children. If you do not know how to solder, check out How To Solder and Desolder Connections to learn how before beginning this guide.
Turn the device upside down.
Apply constant pressure to the base of your Audiovox, while holding the plastic casing until the casing is completely removed.
Remove the four screws from the base using a Phillips #1 screwdriver.
Turn the device right-side up.
Gently pull the top panel off of the device.
Using a Phillips #1 screwdriver, remove the screw found in the middle of the board.
Pull back the board gently to avoid disconnecting the attached wires.
One by one, de-solder the two wires that connect the power adapter to your Audiovox.
Insert the wires of the new adapter into the designated holes and solder them into place.
