Audiovox CDM-8910 Rear Case Replacement
  1. Audiovox CDM-8910 Rear Case Replacement, Antenna: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the antenna (shown in red box) at the top of the phone when closed.
  2. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your thumb and index finger, grip the antenna near its base and unscrew counter clockwise. Once loose, remove the antenna by pulling it from its insert hole.
  3. Audiovox CDM-8910 Rear Case Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the back side of the phone.
    • The battery is the large main compartment (red box).
  4. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your finger to slide the latch (circled) upwards.
    • While holding the latch up, pull the battery off the phone.
  5. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back of the phone will look like this when the battery is correctly removed.
  6. Audiovox CDM-8910 Rear Case Replacement, Rear Case: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Peel the rubber indicated toward the top of the phone
  7. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the screw that sits underneath the rubber covering.
  8. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the five (5) total screws using a Philips head screwdriver.
  9. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use spudger and insert it towards the bottom of the phone as pictured.
    • Carefully working yourself around the phone with the spudger, pry it open. This may require a bit of force.
    • The volume control button will be loose, so make sure to take it out once the rear case is fully removed.
  10. Audiovox CDM-8910 Rear Case Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • The back case should now be completely removed and the motherboard will be visible.
Carlos Guerrero
crwdns2935283:010/04/10crwdne2935283:0
1 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 3-24, Regan Fall 2010 crwdns2935289:0Cal Poly, Team 3-24, Regan Fall 2010crwdne2935289:0
CPSU-REGAN-F10S3G24
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 1,766
