This guide will show you how to replace the motherboard in an Audiovox CDM-8900 phone. If you're experiencing frequent crashes, unresponsiveness, or any other hardware issues, it might be necessary to replace the motherboard. The motherboard is an essential component of your phone that controls its functions and houses the central processing unit (CPU). In this guide, we'll give you step-by-step instructions on how to replace the motherboard of your Audiovox CDM-8900 cell phone.
Before you begin the replacement process, it's crucial to back up your data and ensure that you have the correct replacement motherboard for your Audiovox CDM-8900. So, let's get started and restore your phone's performance!
Hold the phone in one hand, slide the latch up, and pull the battery up to remove it.
Grasp the antenna at its base and twist to unscrew.
Remove the small rubber insert from the top of the phone to access the top screw.
Unscrew all five screws on the back of the cell phone with a Phillips #00 screwdriver.
Wedge the phone plate toward you, using the leverage from an opening tool.
Detach the motherboard from the LCD screen connector by gently detaching the small copper plate on the top right of the motherboard.
To release the motherboard, push the large "OK" button located on the other side of the phone.
