This guide will show you how to replace the main inside LCD screen on the Audiovox CDM-8900.
Remove four screw covers using the spudger.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Remove the four Phillips #00 screws.
Wedge one of the plastic opening tools under the phone cover near the hinge.
Insert the second plastic opening tool under the phone cover and slide it around the perimeter.
Detach the phone cover from the phone's base.
Slide out the two metal braces located along the sides of the LCD screen.
Carefully peel back the tape from both sides of the copper frame.
Using the spudger, carefully separate the speaker and microphone from the inside surface of the phone.
Gently lift the copper frame surrounding the LCD screen.
With the copper screen lifted up, gently pull out the ribbon connector and lift out the LCD screen.
