Audio-Technica LP60XBT Turntable Gear Replacement
  1. Audio-Technica LP60XBT Turntable Gear Replacement, Gear: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio-Technica LP60XBT Turntable Gear Replacement, Gear: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the felt pad, and put it to the side.
  2. Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the platter so that the brass motor pulley can be seen through one of the two outer holes in the platter.
    • If the drive belt is hooked around the motor pulley, unhook it.
    • When reassembling to device, don't forget to hook the new drive belt to the motor pulley.
  3. Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the platter by grasping the platter by its two inner holes and lifting it upwards.
    • If the drive belt is unhooked and the tone arm is safely to the side, don’t be afraid to use a small amount of force in lifting the platter if necessary.
  4. Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four screws holding in the gears using a Phillips #0 screwdriver.
  5. Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the large white gear by pulling it upwards.
    • Remove the small white gear and base by pulling them upwards.
  6. Audio-Technica LP60XBT Turntable Gear Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Insert the small replacement gear first, then the large replacement gear second.
    • When replacing the smaller gear and base, be sure to feed the black ground wire through the hole in the base.
crwdns2935229:05crwdne2935229:0
Devon Ferreira
crwdns2935283:003/22/21crwdne2935283:0
238 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S1-G8, Sinclaire Spring 2021 crwdns2935289:0UMass Dartmouth, Team S1-G8, Sinclaire Spring 2021crwdne2935289:0
UMASSD-SINCLAIRE-S21S1G8
crwdns2936753:030crwdne2936753:0 54
crwdns2942667:0crwdne2942667:0 2,144
