This guide will deal with how to replace the broken or missing belt drive for Audio-Technica AT-LP60BK-BT Bluetooth Wireless Turntable. The rubber band could cause a malfunction and break after using a long time or under extreme temperatures.
Before using this guide, make sure the size of the new belt is designed specifically for this model to avoid motor overheat problem.
Open the top plastic cover and remove the record and rubber mat.
Find the belt underneath the platter by rotating the platter to the correct place.
Remove the belt from the motor pulley.
Take the platter off by pulling it straight up.
Place the new belt around the inner lap on the upside-down platter.
Turn the platter around.
Grab the belt around with a finger through one of the holes in the platter.
Put the belt around the motor pulley.
Test the function by spinning the platter and put the rubber mat into place.
This is so much more helpful than the instructions on the Audiotechnica website. Thank you!
This was a fantastic guide! Helped me out when the platter got loose during a move. Thanks dude!
Thank you so much!
Ditto that! Thanks for the clear directions.
Super easy to follow, thank you!!
