crwdns2959928:0crwdne2959928:0 ↓If the difficulty button on an Atari Flashback 2 console is sticking or broken, then it will need to be cleaned or replaced. This guide covers the steps necessary to disassemble the console in order to access the buttons for replacement.
Using the screwdriver and the PH1 bit, unscrew the five 10.0 mm screws on the bottom of the console.
Unscrew the two 10.0 mm Phillips #1 screws, and gently pull back the green circuit board.
