Tools needed include an iFixit opening tool, a metal spudger, a removable head screwdriver with a T3 bit and a PH0 bit, and needle-nosed tweezers.
Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
Gently move the tool around the edges towards each corner until the back is removed.
Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use the tweezers to gently pull up on the flaps beneath the two cameras.
Completely remove the cameras and replace with the new cameras.
You can read T3 in the summary and T4 in the instructions: which one do I need?
Does this fix the Zenfone 4 max camera black screen?
this is not right..
Filipe Silva - crwdns2934203:0crwdne2934203:0
