Asus Zenfone 4 Max Camera Replacement
  1. Asus Zenfone 4 Max Camera Replacement, Camera: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a removable head screwdriver and a T4 bit, remove the screws on the base of the phone on either side of the charging port.
  2. Asus Zenfone 4 Max Camera Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Starting near either of the 4 corners of the device notice the seam of the case around the front of the device.
    • Begin using the opening tool with a moderate amount of force to wedge between the back case and the phone.
    • Gently move the tool around the edges towards each corner until the back is removed.
    • You will be able to hear the back casing pulling apart from the phone. Do not be alarmed, but work gently with the device.
  3. Asus Zenfone 4 Max Camera Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenfone 4 Max Camera Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a removable head screwdriver and a PH0 bit, begin removing the panel beneath the two cameras by unscrewing the screw.
  4. Asus Zenfone 4 Max Camera Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenfone 4 Max Camera Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenfone 4 Max Camera Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the tweezers to gently pull up on the flaps beneath the two cameras.
    • Completely remove the cameras and replace with the new cameras.
Maegan West
crwdns2935283:010/02/18crwdne2935283:0
839 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team S11-G6, Blackburne Fall 2018 crwdns2935289:0Sam Houston State, Team S11-G6, Blackburne Fall 2018crwdne2935289:0
SHSU-BLACKBURNE-F18S11G6
You can read T3 in the summary and T4 in the instructions: which one do I need?
patriziomaugeri - crwdns2934203:0crwdne2934203:0
Does this fix the Zenfone 4 max camera black screen?
Roger Dufault - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,100
