crwdns2959928:0crwdne2959928:0 ↓Upgrade the RAM in your laptop.
Spudger4.9
crwdns2935267:0crwdne2935267:0T5 Torx Screwdriver$9.99
Remove the twelve 3 mm bottom panel screws with a T5 Torx Screwdriver.
Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
Remove the bottom panel from the body of the laptop.
Set aside the bottom panel.
Push away the RAM retaining arms from the RAM chip.
Remove the RAM chip completely.
Replaced the 4 GB RAM module in my UX32VD with an 8 GB Timetec Hynix IC DDR3 1600MHz PC3-12800 Non ECC Unbuffered 1.35V CL11 2Rx8 Dual Rank 204 Pin SODIMM Laptop Notebook Computer Memory Ram Module using this guide. It worked like a charm. Thank you for posting the guide!
Le Zap - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
Worked like a charm on a UX32VD. Installed a "Kingston SO-DDR3L-RAM ValueRAM 1600 MHz 1x 8 GB" in 3min
HUGE DIFFERENCE
Thank you very much!
PS. There was a foil wrapper around the old RAM that I removed and put around the new RAM. Heat dissipation I imagine
Valentin - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
