Asus Zenbook UX32VD Battery Replacement
  1. Asus Zenbook UX32VD Battery Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement, Bottom Panel: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    T5 Torx Screwdriver
    $9.99
  2. Asus Zenbook UX32VD Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to pry along the perimeter of the bottom panel until it can be easily removed.
    • Remove the bottom panel from the body of the laptop.
    • Set aside the bottom panel.
  3. Asus Zenbook UX32VD Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement, Battery: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eight 3 mm Phillips #0 screws on the bottom panel.
  4. Asus Zenbook UX32VD Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry up each side of the flat connectors by hand or with a plastic opening tool.
    • Lift the connector straight up from its socket.
  5. Asus Zenbook UX32VD Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX32VD Battery Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unplug the two bundled cable connectors on each side of the battery.
    • Pull the cable away from the connector in the same direction as the individual wires are running.
    • Pull evenly on the full width of the cable so that no individual wires are overly strained.
    Unnecessary step. Just detach the speakers from the sides of the actual battery and leave them to the computer with wires connected. They are just attached with some 2-sided tape, easy to remove when you lift up the battery just a bit.
    Also, if you decide to remove the speakers, the connectors should not be detached by pulling from the wires, the force should be applied directly to the connector with proper tool.
    Touko Korpela - crwdns2934203:0crwdne2934203:0
  6. Asus Zenbook UX32VD Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery completely.
    Battery replacement is pretty easy procedure for Asus Zenbook series. You also can check on my video how to replace the motherboard, which is more complex, but can be accomplished with mid level of experience.. https://www.youtube.com/watch?v=jJLl5DhY...
    Even the video is for another model, you still can apply the same technique to another models from Zenbook series.
    Kostya Kostyushko - crwdns2934203:0crwdne2934203:0
Jenny Nguy
crwdns2935283:009/17/15crwdne2935283:0
180 crwdns2915208:0crwdne2915208:0
CSU Fullerton, Team 2-2, Bruce Fall 2015 crwdns2935289:0CSU Fullerton, Team 2-2, Bruce Fall 2015crwdne2935289:0
CSUF-BRUCE-F15S2G2
crwdns2947412:05crwdne2947412:0
what is the color code of the battery wiring? especially for the white and yellow
Asim Ahmed - crwdns2934203:0crwdne2934203:0
Will this method also apply to ASUS Zenbook UX430UQ ?
Kurt Scheel - crwdns2934203:0crwdne2934203:0
Is this the same method for ASUS Zenbook UX430UQ-GV050T ?
this is probably odd, but can someone recommend me battery and speakers?
I did small research, have not found any speakers and found a few options with battery, but all of them looks suspicious, some comments like - dead after 1 year and etc...
Regards
Nikolay Em - crwdns2934203:0crwdne2934203:0
Why would you replace the speakers? I don't ever understand, why would you unplug the speakers (as it's done in these instructions)? They are just taped on side of the battery, once you lift up the battery a little bit, you can take the speakers off from the battery pack and leave them on their place while replacing the battery.
crwdns2942667:0crwdne2942667:0 18,130
