Use this guide if booting is an issue or if you want to upgrade the amount of storage your SSD has. Replacing the SSD in the ASUS ZenBook UX31E is relatively easy and should not take much time.
Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
Carefully slide your iFixit Opening Tool between the back panel.
Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
Peel back the warranty sticker to reveal the screw under it.
Using your Phillips #00 Precision Screwdriver, unscrew the screw that you just revealed.
Using your hand, pull the SSD out from its slot.
crwdns2935229:09crwdne2935229:0
Vorrei fare una precisazione, l’SSD che monta questo laptop ha un attacco XM11, oramai non si usa più, pertanto è vero che possiamo sostituirlo ma dobbiamo aver cura di prendere un SSD M2 (2280) e un adattatore, io ho trovato su Amazon questo https://www.amazon.it/gp/product/B00XJRQ...
e ho preso come SSD un Crucial MX500 CT1000MX500SSD4 SSD Interno, 1 TB, 3D NAND, SATA, M.2 (2280)
Dade UD - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
