Asus Zenbook UX31E Fan Replacement
  1. Asus Zenbook UX31E Fan Replacement, Back Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using a T4 Torx screwdriver, remove the ten screws at the marked locations.
    • Place the screws into a container as to not lose them.
    Can you tell me what size these screws are? I need to replace two.
    Elliot Lozano - crwdns2934203:0crwdne2934203:0
    I don’t know, but you can search with product code: VISTORXUX31E
    See also: https://en.accessoires-asus.com/torx-scr...|l
    Davide Bortot -
  2. Asus Zenbook UX31E Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Carefully slide your iFixit Opening Tool between the back panel.
    • Lift the back plate of your ASUS ZenBook UX31E, and place it to the side.
  3. Asus Zenbook UX31E Fan Replacement, Fan: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31E Fan Replacement, Fan: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the ribbon between the IO and the motherboard on both sides.
    To remove the ribbon, use a spudger to lift up the black plactic tab which holds the cable
    lauhub - crwdns2934203:0crwdne2934203:0
  4. Asus Zenbook UX31E Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the fan connector from the motherboard.
    • Pull up the clips on the ribbon connectors.
  5. Asus Zenbook UX31E Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31E Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the two screws that are across each other.
  6. Asus Zenbook UX31E Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31E Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using a plastic opening tool, lift the fan off of the laptop.
    • You can now use your hands and carefully pull the fan off the laptop.
Sinh
crwdns2935283:002/01/17crwdne2935283:0
UW Tacoma, Team 1-2, Rose Winter 2017 crwdns2935289:0UW Tacoma, Team 1-2, Rose Winter 2017crwdne2935289:0
UWT-ROSE-W17S1G2
This guide does not explain how to replace the fan, but how to remove the fan.
How do you insert a new fan? (Specifically, how do you remove the fan from the component of which it is a part?)
Thank you in advance.
Albert - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 1,768
