Asus Zenbook UX31A Touchpad Replacement
  1. Asus Zenbook UX31A Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31A Touchpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Touchpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Touchpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Touchpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Touchpad Replacement, Touchpad: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #1 screwdriver to remove all four 6 mm screws from the trackpad.
  6. Asus Zenbook UX31A Touchpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use your fingers or a nylon spuder to gently lift the track pad ZIF tab, and pull the ribbon cable free.
    • Be gentle with this wire since it is fragile
  7. Asus Zenbook UX31A Touchpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift up and pull backwards to remove the touchpad
Christopoher Orser
crwdns2935283:003/22/22crwdne2935283:0
294 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 crwdns2935289:0UMass Dartmouth, Team 7-1, Sinclaire Spring 2022crwdne2935289:0
UMASSD-SINCLAIRE-S22S7G1
crwdns2942667:0crwdne2942667:0 964
