Asus Zenbook UX31A Daughterboard Replacement
  1. Asus Zenbook UX31A Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31A Daughterboard Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use a T6 screwdriver to remove the ten 6 mm case screws.
    • The two screws adjacent to the device serial number stamps are longer than the others. These two screws run about 11 mm long.
    • Remove the back cover from the laptop.
    • DO NOT BEND OR PUNCTURE THE BATTERY: Puncturing the battery can result in injury since the battery can catch fire or explode when exposed directly to oxygen
  2. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the three 7 mm screws that secure the battery.
  3. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unplug the bundled battery connector from the motherboard by gently pulling the cable up.
    • Make sure you pull the connector directly upwards or you could damage the connector
  4. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the battery from the laptop by lifting it up and out.
  5. Asus Zenbook UX31A Daughterboard Replacement, Fan: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31A Daughterboard Replacement, Fan: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unclip both ZIF connector tabs by lifting the black tab up and away from the connector.
    • Remove the bridge connector.
  6. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove all seven 6 mm screws that secure the fan and heatsink.
  7. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the fan connector by pulling on it horizontally until it disconnects.
    • Remove the fan.
  8. Asus Zenbook UX31A Daughterboard Replacement, Daughterboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to detach the cable from the board by pulling them gently toward the bottom edge of the board.
  9. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #00 screwdriver to remove the 6 mm screw that secures the daughterboard.
  10. Asus Zenbook UX31A Daughterboard Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove by carefully lifting the board from the laptop.
Sherwin
crwdns2935283:003/22/22crwdne2935283:0
209 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team 7-1, Sinclaire Spring 2022 crwdns2935289:0UMass Dartmouth, Team 7-1, Sinclaire Spring 2022crwdne2935289:0
UMASSD-SINCLAIRE-S22S7G1
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 287
