Asus ZenWatch 2 Motherboard Replacement
  1. Asus ZenWatch 2 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 3.5mm screws using a T5 screwdriver to open the faceplate.
  2. Asus ZenWatch 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenWatch 2 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the two 1.8mm silver screws using the PH00 screwdriver.
  3. Asus ZenWatch 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenWatch 2 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the spudger under the gold-plated connection ribbon and lift to disconnect from the motherboard.
  4. Asus ZenWatch 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenWatch 2 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pull up on the motherboard using tweezers to detach it from the watch.
Andrew
crwdns2935283:002/20/17crwdne2935283:0
314 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G1, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G1
Step 3 requires three different connectors to be removed from the mainboard. Not one. Attempting to remove the mainboard after only disconnecting the gold-plated connector can result in damaged digitizer/display cable.
s3ae - crwdns2934203:0crwdne2934203:0
Out of curiosity, I don’t see the battery hiding in any of the pictures. Is it glued or otherwise attached to the backplate of the watch, and since you’re focused on the mainboard, we’re not seeing it for that reason? Thanks!
MD5Hash - crwdns2934203:0crwdne2934203:0
Battery is actually stuck to the bottom side of the case. It looks to be pretty easy to replace. Connection is done with 4 sets of pins (at least 2 for battery)
Jean-Guy Rivard -
Where can you purchase a replacement motherboard?
Tasha Kanahele - crwdns2934203:0crwdne2934203:0
My zenfone wach 2 all function not showing please help me
Akhtar - crwdns2934203:0crwdne2934203:0
Nececito la placa madre dónde la consigo
Álvaro Lopez - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,700
