Asus ZenWatch 2 Battery Replacement
  1. Asus ZenWatch 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenWatch 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenWatch 2 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four 3.5mm screws to detach the case using the T5 screwdriver.
  2. Asus ZenWatch 2 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenWatch 2 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Slide the spudger under the battery and lift to remove.
    my zenwatch 2 is all together different it has a plug on top and a piece of metal hooked to the back of battery that looks like it is made on the watch
    glrichy - crwdns2934203:0crwdne2934203:0
crwdns2935229:015crwdne2935229:0
Moriah
crwdns2935283:002/20/17crwdne2935283:0
775 crwdns2915208:0crwdne2915208:0
USF Tampa, Team S1-G1, Leahy Spring 2017 crwdns2935289:0USF Tampa, Team S1-G1, Leahy Spring 2017crwdne2935289:0
USFT-LEAHY-S17S1G1
crwdns2947412:013crwdne2947412:0
Where do you get the battery?
Mark Miser - crwdns2934203:0crwdne2934203:0
Sir,
I own Zenwatch 2 and it is just 14 months old. I left it uncharged for months. Now it is not at all charging. In Service Centre, they said Asus did not send any replacement spares even to test what was wrong.
I am from Mumbai, India. Where can i purchase replacement Battery so that i can try? Please help me sir.
Vijaykumar S
Mumbai
vijai kumar - crwdns2934203:0crwdne2934203:0
Hello I have ZenWatch 2 Battery WI502Q-SL-BD need help looking Replacement Battery
Angel Alfredo Grant - crwdns2934203:0crwdne2934203:0
i used non original battery, link here. Compare here.
4spam - crwdns2934203:0crwdne2934203:0
Need soldering? I see it didn't have the connector.
Tendou -
i bought this battery as i belevied it to be compatible - but unfortunately the 2 contacts on the battery are not the same spacing as the original battery
anyone have any experience of swapping the circuit board of the contact between the 2 batteries? i feel this may be my only option of reusing my watch as this is the only manufacturer i have been able to locate :(
robert - crwdns2934203:0crwdne2934203:0
I’ve replaced the battery with an aftermarket one, but now I’ve attached the charging cable and it just buzzes every 2 seconds. No charging progress, no boot screen. I can’t find any mention of this anywhere, but my guess is it doesn’t detect the battery. Anyone see this before? I might have to open it up again and reseat the battery, and those tiny T5 screws are a pain — the worst part was getting them back in, they kept getting attracted by the magnetic charger!
Max - crwdns2934203:0crwdne2934203:0
Never mind, the watch made the same buzzing pattern when I left the battery out and connected the charging cable. It looks like the contacts are spaced slightly differently, like robert described. I’m returning it for a refund, and I’ll try another one.
My zenwatch is 3 years old, roughly.
When I bought the replacement battery, it too did not line up the contacts well either,
I held up the battery in the cover to the main housing of the watch and noticed how much the contacts were misaligned. I bent the posts slightly, GENTLY, and put the cover back on.
While I wouldn't recommend this, it does work.
I was ready to buy a different watch if I snapped a post, but got lucky.
I just hope this battery holds a charge better. I was getting about four hours of life from the original.
sykmot - crwdns2934203:0crwdne2934203:0
Update: the battery I used is the same as robert above. Here’s an amazon link for it:
https://www.amazon.com/dp/B07N7515XD/ref...
the battery has been giving me about 48 hours of use time.
sykmot -
Donde comprar batería para reloj Asus ZenWatch2 model:WI501Q
Jesús Duesca - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 18,017
