Asus ZenFone 5 Motherboard Replacement
  1. Asus ZenFone 5 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement, Motherboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
    • Pull out the SIM card tray.
  2. Asus ZenFone 5 Motherboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
    • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
    • Move all the way around the phone until the back cover is separated from the rest of the phone.
    • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
  3. Asus ZenFone 5 Motherboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
  4. Asus ZenFone 5 Motherboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
    • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
    • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
  5. Asus ZenFone 5 Motherboard Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently use a spudger to remove the wired connections on the motherboard.
    • Disconnect both ribbon cables by popping up the locking tab of the zif connectors and pulling the cable out.
    • Pry up the black coaxial cable and it will pop off its connector on the motherboard.
    • Remove the two screws holding down the motherboard with a Phillips #00 screwdriver.
  6. Asus ZenFone 5 Motherboard Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Motherboard Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert the pointed end of a spudger into the red rubber divot underneath the motherboard.
    • Gently pry the motherboard from the device.
Aaron Michael Melton
crwdns2935283:009/17/20crwdne2935283:0
169 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G20, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G20, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S3G20
crwdns2936753:030crwdne2936753:0 36
crwdns2942667:0crwdne2942667:0 2,101
