Asus ZenFone 5 Battery Replacement
  1. Asus ZenFone 5 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a SIM card removal tool or the end of a paperclip into the small hole on the lefthand side of the phone to release the SIM card.
    • Pull out the SIM card tray.
  2. Asus ZenFone 5 Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • It may help to apply heat to the back cover using either a heat gun or an iOpener before starting to remove the cover.
    • Use a plastic opening pick to pry into the crease between the back cover and the midframe of the phone.
    • Move all the way around the phone until the back cover is separated from the rest of the phone.
    • The images show a metal spudger being used to pry open the back cover. However, this process is not recommended, as it poses a puncture risk to the battery.
  3. Asus ZenFone 5 Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using a Phillips #00 screwdriver, remove the six screws across the top mid frame and gently lift the top assembly piece. It should detach easily and can be set aside.
  4. Asus ZenFone 5 Battery Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a plastic opening tool to release the red square that is holding the bottom assembly piece from the frame.
    • Using a Phillips #00 screwdriver, remove the five screws from the bottom midframe.
    • Gently remove the bottom midframe.
  5. Asus ZenFone 5 Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenFone 5 Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    Halberd Spudger
    $2.99
    • Use a halberd spudger to pry up the battery's press fit connector from the motherboard.
    • Gently pry the battery out of the case, taking care not to bend or puncture the battery.
    • It may help to apply a bit of heat through the screen to loosen the battery adhesive.
    Thanks a lot for this Guide, it looks great and full of details!
    I should replace my Zenfone 5 battery, where should i get i new one?
    Thanks Again
    Francesco
    Francesco Campana - crwdns2934203:0crwdne2934203:0
Andrew Michael Finkle
crwdns2935283:009/17/20crwdne2935283:0
139 crwdns2915208:0crwdne2915208:0
The Citadel Military College of South Carolina, Team S3-G20, Eggleston Fall 2020 crwdns2935289:0The Citadel Military College of South Carolina, Team S3-G20, Eggleston Fall 2020crwdne2935289:0
CMCSC-EGGLESTON-F20S3G20
Wait, Asus Zenfone 5 (ZE620KL, ZF620KL) has only 3300 mAh battery capacity. Why in the image above the battery label say it's 4000 mAh?
Jufans Anurwan - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 5,387
