Replacing the motherboard will take a good amount of time. Before replacing the motherboard, you will need to unplug the entire antenna and take out the battery.
Use your fingernail to gently pry off the phone's back cover at the indicated location. While your fingernail is under the back cover slide your finger around the edges of the phone until the cover pops off.
Remove the thirteen black screws and the single silver screw from the back of the phone with a JIS size 00 screwdriver.
The black screws are 2.8 mm in length.
The silver screw is 5.5 mm in length.
The screw next to the camera with the sticker on (top middle on screen) was T4 not J00
Use a plastic opening tool to remove the inner phone backing.
Take the speaker out of the back of the phone. It should come out easily as soon as the inner back is removed because nothing is holding it down in place anymore.
Use a plastic opening tool to gently pry up both ends of the antenna.
Carefully remove the antenna wire from the plastic keepers along the side. Note their position for reassembly.
It is very important to lift it form underneath... The connector on the motherboard is very fragile.
Is there any way to actually replace the port? It got ripped off mine.
I am wondering how to repair it, it got ripped off as well.
Hello Guile,
I ripped the connector of gsm antenna on the other side (mainboard side) is there any way to fix it? It May be connect another contact point?
same problem...solutions?
Same problem any solution?
Same problem too... :(
Is this wifi antenna?
Using the plastic opening tool, unlock the ribbon cable attaching the battery to the circuit board by prying up the yellow tab.
Using a plastic opening tool, gently pry the vibration motor from its mount.
This image is too dark and there is no marker to identify the vibration motor.
Gently remove the circuit board from the phone by gently pulling it away from the bottom of the phone.
There´s some adhesive tape holding the ribbon cable on to the flat connector, it needs to be carefully raised before this board can be removed.
Using the plastic opening tool, disconnect the ribbon cables from their connectors by gently prying them up.
Suggest rotating the phone in your hand to better access the ribbon cables?
Carefully remove the battery pack from the phone using your hand. The battery is glued in placed by a strip of adhesive on the top side so some force may be necessary.
The battery is glued in placed by a strip of adhesive on the top side so some force may be necessary. In my case the strip of adhesive is on the long right side of the battery.
Using a plastic opening tool, lift the copper sheet heat strip from the body of the phone by sticking the tool into one of the upper corner of the copper sheet and slowly sliding it along the edges.
Using a plastic opening tool, unplug the ribbon cable indicated in the picture.
Using a plastic opening tool, disconnect the display cable from the side of the motherboard by carefully sticking the tool underneath the display cable and gently pulling outward.
The cable should not be pulled that way… you could damage it (I learned it the hard way). Pull up the metal shielding first then un-hatch the locking mechanism inside…
Yes. I destroyed a motherboard like this. I guess that is what I get for listening to only one instruction.
There are four black plastic retainers, two on each side, that keep the motherboard fix in place. To get the motherboard out, stick a plastic opening tool under one top corner of the motherboard and carefully lift upward using a small amount of force to pop this side of the motherboard out of the plastic retainers.
Once one side of the motherboard is out of the black plastic retainers, remove the whole motherboard from the phone.
Put in a new motherboard and reassemble your device by following these instructions in reverse order.
crwdns2935229:041crwdne2935229:0
crwdns2944067:020crwdne2944067:0
Hi!I
After replacing the complete appliance front but the unit turns on but nothing appears on the screen, what may have happened?
Check if the screen ribbon cable is firmly attached to the motherboard. If it is you may have a faulty motherboard replaced or a faulty screen
Thanks this helped a lot, Download Asus full firmware here: https://www.droidtechie.com/official-ful...
Is there any place where I can order just the audio jack?
Is there a reliable source to buy a motherboard you can suggest? I need to replace the audio jack. Thank you for the neat guide.
I want to buy asus zenfone 2 audio jack part..... Plz help me how to get my order
On my unit the problem is not the audio jack itself but the soldering point that is broken. I contacted Asus for the part and they don't want to sell it...
i want to buy zenfone 2 ze551ml motherboard please please help me where i can get it at low cost............ please inform me it`s urgent....
how much is the board of asus zenfone 2? I accidentally drop mine in the sea while on vacation and my phone is shorted 100% and they said I have to replace the board and with that I also have to loose my files and pics. everything. thanks
Hi i need a motherboard for asus ZenFone 2 z00ad how can i bye it.?
hi..
how to identify the UEM of Asus 2 and Asus 6?
Dopo che si e sostituisce la scheda madre ce bisogno di: installare i drive r il sistema operattivo?
Quando viene acceso per la prima volta Dopo che ho installato la scheda madre cosa si deve fare?
Hi i want to purchase Asus Zenfone laser 2 motherboard kindly help me.
+919838587378
hello Guys, I had to reset my Asus Zenfone 2 laser because of auto restarting which couldn’t reach the principle manager system. now I cannot access google account and phone manager. all my access stop at the setting, please kindly assist.
Where we can get new motherboard of Asus zenfone 2 laser ze550kl
Hello will you help me were to asus zooad touchscreen bodyhousing.email mme rommeldp89@yahoo.com
Please help me were to buy asus zooad touchscreen and bodyhousing email rommeldp89@yahoo.com
Is there any site where I can order Power IC for Asus Zenfone 2 Laser? or Motherboard for Zenfone 2 laser 3G/32G?
