Asus ZenBook UX330U Trackpad Replacement
    1. Asus ZenBook UX330U Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement, Battery: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Before starting any device dissasembly, please put on the anti-static bracelet provided by iFixit. Make sure the metal part of the bracelet is touching your skin.
      • Remove the alligator clip at the end of the bracelet by simply pulling it off, to reveal the bullet connector.
      • Insert the bullet connector into the ground port of an outlet.
      • Make sure to keep the bracelet on at all times while disassembling your device, to prevent ESD to the components.
    2. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Power off the device and make sure it is physically unplugged before starting any disassembly procedures.
      • Remove the eight 3.1 mm screws using the T5 Torx screwdriver.
      • Remove the longer 5.1 mm screw using the T5 Torx screwdriver.
    3. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use a Jimmy or a spudger to pry off the two rubber feet that are closest to the hinge.
      • Unscrew the two 5.6mm screws that were underneath the rubber feet using the Philips #0 screwdriver bit.
      • The rubber feet may be difficult to remove. Do not hesitate to use more force to remove the feet, if necessary.
    4. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Press the suction handle on the center of the back cover, and gently lift up.
      • You may need to wiggle the back cover as you lift it in order to take it off easily.
    5. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Unscrew the six 3.7mm screws using the Philips #0 screwdriver bit.
      • Be extra cautious when handling the battery. If the battery looks swollen or damaged, consult this guide.
    6. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the four 2.8mm screws from the motherboard ribbon connector using the Philips #0 screwdriver bit.
      • You may have to pull back the black tape located on the bottom right motherboard connector screw. This tape is not necessary for the functionality of the device and can be discarded if necessary.
    7. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the motherboard ribbon connector by pulling up on the metal ends with the blunt nose tweezers.
      • You may have to hold down the black tape in order to be able to lift up the connector.
      • To reconnect the motherboard ribbon, simply press the ends of the ribbon on top of the connector. This should require minimal force.
    8. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Pull back the silver battery connector lock with the blunt nose tweezers. This should slide back and should require minimal force.
      • Lift the battery connector vertically using the blunt nose tweezers to remove it from the socket.
    9. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Gently lift the battery out of the chassis of the device.
      • Make sure that you do not bend the battery.
    1. Asus ZenBook UX330U Trackpad Replacement, Trackpad: crwdns2935265:010crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement, Trackpad: crwdns2935265:010crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement, Trackpad: crwdns2935265:010crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Use the tweezers to unlatch the clasp holding the ribbon cable
    2. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Using the tweezers again, pull on the blue plastic tab with “TP” printed on it.
      • Be careful not to pull directly on the white part of the ribbon cable. Doing so could result in damage to the ribbon cable itself.
    3. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Remove the strip of tape by grabbing the end of it with the blunt nose tweezers and pulling back.
    4. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
      • Remove the three 2.5 mm screws across the top of the trackpad with the Philips #0 screwdriver.
    5. Asus ZenBook UX330U Trackpad Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slightly lift the trackpad from the top edge and pull it away from you.
Hasan Akpunar
crwdns2935283:009/20/19crwdne2935283:0
1,475 crwdns2915208:0crwdne2915208:0
Embry-Riddle Aeronautical University, Team S1-G111, Watkins Fall 2019 crwdns2935289:0Embry-Riddle Aeronautical University, Team S1-G111, Watkins Fall 2019crwdne2935289:0
ERAU-WATKINS-F19S1G111
crwdns2935297:035crwdne2935297:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 1,794
