This guide will show you how to replace the motherboard on an Asus ZenBook UX303U laptop.
Remove the two round rubber feet at the hinge-edge of the laptop.
Remove the eleven 4 mm Phillips #00 screws from the back panel.
These screws on other models are Torx T5 or T6, not Phillips
T4 screws on all but the two under the rear rubber feet; those are Phillips PH0 (and my model had two square rubber feet).
Agree. Same as my laptop.
Moops -
Using a plastic opening tool pry the back panel off of the laptop.
I lift more than the last photo shows. Dark rubber with plots, visible on photo are blocking the opening.
Mine was also stuck at the back with a bit of tape (for grounding?) I did my best to make sure it was replaced during re-assembly.
Pull the speaker cable out of its four retaining clips with either your fingers, or a plastic opening tool.
Skip this step on UX430U
I skipped this step and was able to gently pull it out when I removed the battery in step 8.
Remove all seven 2 mm Phillips #00 screws from the battery.
Pull the speaker connector toward the edge of the laptop to disconnect it from its socket.
Lift the battery connector straight up off its socket to disconnect it from the motherboard.
The replacement battery I received from ifixit had longer wires than the original battery which made re-installing it a bit awkward, but I was able to bend them to the side a bit.
Lift the battery and speakers up and pull out to remove.
Remove the speakers from the old battery.
This was a bit more fiddly than expected given the speaker arms are stuck to the battery
Yes, it was taped on their quite strongly. I just tried to make sure the tape stayed stuck to the speakers and not the battery.
Moops -
Disconnect the display cable from the motherboard with a plastic opening tool.
Remove the three 6mm Phillips #00 screws from the hinge.
Remove the 2mm Phillips #00 screw from the plastic housing securing the fan into place.
Lift the screen assembly hinge up and off of the motherboard fan.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using tweezers, disconnect the cable connector from the motherboard fan.
Lift the fan up and off of the white pegs that secure it into place.
Remove eleven 4mm Phillips #00 screws.
Disconnect all wires connecting the motherboard to the rest of the device.
For the two connectors marked in orange, lift the black clip up to release the wire.
For the wire marked in yellow, lift it straight up.
crwdns2935229:05crwdne2935229:0
The bottom of the pictured device may feature Phillips #00 screws, but I also have this laptop and the screws around the edge of the bottom panel are Torx T5s on my device.
The process took me about 30 minutes. If I were to have to do it again then I could probably do it in 10 minutes now that I know what is involved!
Jon Kerridge - crwdns2934203:0crwdne2934203:0
