Asus X751L Battery Replacement
  1. Asus X751L Battery Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the six 14.6mm Phillips #00 screws.
    • Remove the four 6.6mm Phillips #00 screws.
  2. Asus X751L Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip the laptop over and open the lid.
    • Pry around the edges of the laptop base using the plastic opening tool.
    • Prying too hard can break the plastic clips.
  3. Asus X751L Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X751L Battery Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X751L Battery Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Carefully lift the keyboard up.
    • Be very careful when lifting the keyboard up. Two zero insertion force (ZIF) cables are between the keyboard assembly and the motherboard. Do not lift the assembly too high.
    • Disconnect the two ZIF connectors from the motherboard using your fingernail to lift the cream-colored tab.
  4. Asus X751L Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 6.6mm Phillips #00 screws holding the battery in place.
  5. Asus X751L Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X751L Battery Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the battery from the cable-side to maneuver it around the plastic clips.
  6. Asus X751L Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X751L Battery Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X751L Battery Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Using your finger nails, gently push the battery cable out of the connector on the motherboard.
    • Once the cable is disconnected, you can remove the battery.
John Enderton
crwdns2935283:002/02/17crwdne2935283:0
576 crwdns2915208:0crwdne2915208:0
USF Tampa, Team 17-2, Blackwell Spring 2017 crwdns2935289:0USF Tampa, Team 17-2, Blackwell Spring 2017crwdne2935289:0
USFT-BLACKWELL-S17S17G2
Took me awhile to figure out how to get the cables back. Other than that, good insturctions.
Jacqueline Foxall - crwdns2934203:0crwdne2934203:0
Your instructions were easy to follow. Thank you!!!
theresa collet - crwdns2934203:0crwdne2934203:0
What do the yellow and white wires do ?
Richard Sullivan - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 13,414
