Asus X555LA-SI305041 Keyboard Assembly Replacement
  1. Asus X555LA-SI305041  Keyboard Assembly Replacement, Keyboard Assembly: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following Phillips #0 screws from the lower case:
    • Six 9 mm screws
    • Four 11 mm screws
  2. Asus X555LA-SI305041  Keyboard Assembly Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the top cover from the laptop.
    • Start by prying on the front of the laptop.
    • Continue prying around the cover and end just under the screen to release the front cover.
    • Do not fully remove the top cover, it is attached by two ribbon cables that will be disconnected in the following steps.
  3. Asus X555LA-SI305041  Keyboard Assembly Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To release the ZIF latch, flip up the small white tab.
    • The connector may have a white base with a small grey rotating latch.
    • Pull the white ribbon cable out of the socket to disconnect it.
    • Very little force should be required to pull out the cable.
  4. Asus X555LA-SI305041  Keyboard Assembly Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To release the ZIF latch on the keyboard cable, flip the grey rotating tab up.
    • Gently pull the black and blue ribbon cable out of its connector.
  5. Asus X555LA-SI305041  Keyboard Assembly Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • You can now fully remove the keyboard and front panel to gain access to the inside of the laptop.
crwdns2935229:013crwdne2935229:0
Alex Turner
crwdns2935283:009/28/15crwdne2935283:0
1,927 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team 1-1, Matresse Fall 2015 crwdns2935289:0Eastern Washington University, Team 1-1, Matresse Fall 2015crwdne2935289:0
EWU-MATRESSE-F15S1G1
crwdns2935297:013crwdne2935297:0
Could use some more steps on how to removed completely, including the touch-pad.
Can this be revised soon with more steps and pics? Please.
I need to replaced this keyboard because I have some non-working keys.
Frank P. - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 9,747
