LCD displays are vulnerable to damage and can crack easily. This is one of the most frequently damaged parts on a laptop, so it is good to know how to replace it!
Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
Two 4.3 mm screws in the back corners
One 17.5 mm screw at the left edge near the optical drive
Three 4.3 mm screws in the front edge
Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
Invert the laptop in order to gain access to the ribbons.
Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
Once it is free, remove the hard drive from its internal cavity.
Using the Phillips #0 Screwdriver, unscrew the 5.5 mm Phillips #0 screw that holds the spacer in place.
Remove the spacer from the laptop by gently sliding it towards the right edge of the laptop.
Use the Phillips #0 Screwdriver to unscrew the 3.2 mm Phillips #0 screw which attaches the WiFi card to the motherboard.
Disconnect the Wifi card from the motherboard by gently sliding it towards the right edge of the laptop.
Remove each of the two small antenna connections by disconnecting one wire at a time. Each wire should easily unsnap from the Wifi card.
Remove the battery from the laptop by applying pressure on both ends and lifting it out of the case.
With the Phillips #0 Screwdriver, remove the nine 5.5 mm Phillips #0 screws which hold the motherboard in place.
Now, locate the two wires connected to the motherboard.
Remove the wires by easily pulling them parallel to the motherboard's surface.
Remove the LCD display connection by gently pulling on the attached wire.
Gently lift any tape that may be holding the connection.
Remove the motherboard from the case by gently lifting it upward.
Locate both of the hinges that connect the monitor to the bottom plate cover.
Use the Phillips #0 screwdriver to unscrew the two 4.8 mm Phillips #0 screws on the right hinge, and the one 4.8 mm Phillips #0 screw on the left hinge.
Once the screws are removed, the monitor should easily lift away from the bottom plate cover
Locate the two stickers that cover up the screws that hold the front bezel in place
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Use a pair of tweezers to remove these stickers.
Once the stickers are removed, the two screws that hold the front bezel in place will be exposed.
Use the Phillips #0 screwdriver to remove the two 4.8 mm Phillips #0 screws.
Once the screws are taken out, the front bezel is ready to be removed.
Insert the Plastic Opening Tool inbetween the front and back bezels and slide along the edges to pry open.
Once pried away from the back bezel, the front bezel will easily lift away from the LCD.
Locate the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
Use the Philips #0 screwdriver to remove the twelve 3.2 mm Phillips #0 screws that hold the LCD in place.
Once the screws are removed, lift up the LCD to expose the wire connecting the back bezel to the LCD.
Gently unhook the wire from the back bezel to allow the LCD to be flipped over.
Once flipped over, locate the ribbon that is connected to the back of the LCD.
Gently tug on the ribbon to remove it from the LCD.
Now that the ribbon has been detached from the back, carefully remove the LCD.
crwdns2935229:010crwdne2935229:0
You don't need to disassemble the entire unit to get the panel out. Seems an overkill
Res Q Service - crwdns2934203:0crwdne2934203:0 crwdns2950251:0crwdne2950251:0
