Asus X551CA Hard Drive Replacement
  1. Asus X551CA Hard Drive Replacement, Keyboard Plate Cover: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Power off and unplug your laptop before you begin.
    • Turn the laptop upside-down and remove the following screws using a Phillips #0 driver:
    • Two 9.5 mm screws in the middle of the back edge, and one 9.5 mm screw in the right edge
    • Two 4.3 mm screws in the back corners
    • One 17.5 mm screw at the left edge near the optical drive
    • Three 4.3 mm screws in the front edge
  2. Asus X551CA Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the plastic opening tool to separate the keyboard plate cover from the bottom cover. In order to do this, insert the plastic opening tool in between the keyboard plate cover and the bottom cover, then slide along edges to pry open.
  3. Asus X551CA Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Locate the three ribbons connecting the keyboard plate cover to the bottom cover.
  4. Asus X551CA Hard Drive Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X551CA Hard Drive Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X551CA Hard Drive Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Invert the laptop in order to gain access to the ribbons.
    • Remove each ribbon by flipping the small white plastic flap up and gently pulling on the ribbon.
  5. Asus X551CA Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Now that the ribbons have been detached from the bottom cover, carefully remove the keyboard plate cover. Once it has been removed, place it in a safe and moisture free area so it does not get damaged.
  6. Asus X551CA Hard Drive Replacement, Hard Drive: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three 5.5 mm Phillips #0 screws with the Phillips #0 Screwdriver.
  7. Asus X551CA Hard Drive Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the screws have been removed, place your fingers on the left corners and push the hard drive towards the right edge of the laptop (relative to the picture).
  8. Asus X551CA Hard Drive Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once it is free, remove the hard drive from its internal cavity.
crwdns2935229:048crwdne2935229:0
Brandon
crwdns2935283:004/01/14crwdne2935283:0
2,838 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 7-22, Regan Spring 2014 crwdns2935289:0Cal Poly, Team 7-22, Regan Spring 2014crwdne2935289:0
CPSU-REGAN-S14S7G22
crwdns2947412:08crwdne2947412:0
You mixed up the red and green screws, sizes are wrong.
The red screws are 9.5 not 14.3!
the yellow screws are 4.3 (mixed up with 14.3 ?) not 9.5 !
You do NOT need to remove the ribbons, just use a small screwdriver.
Tony - crwdns2934203:0crwdne2934203:0
Same issue as Tony on 09/03/2014
The screw sizings are mixed up. The red screws are 9.5, not 14.3
The yellow screws are 14.3 not 9.5. Please fix the repair guide text
Mevlan Coma - crwdns2934203:0crwdne2934203:0
It should be fixed now! Thanks to both of you for the tip. By the way, you can always edit the text yourself. ;)
Jeff Suovanen -
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 67,103
