This tutorial demonstrates how to remove the motherboard from your laptop. Doing so allows you to upgrade the CPU, implement a higher quality graphics card, and improve the operating power of your computer.
            Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
            Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
            Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
            This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
   crwdns2935267:0crwdne2935267:0Tweezers$4.99-
            Gently lift the keyboard to access the three ribbon cables connected to the motherboard
            Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
            Gently pull the ribbon cables from their sockets on the motherboard.
            Push the two white clamps on the large ZIF connector towards the screen.
            Gently remove the track pad ribbon cable from its connector.
            Disconnect the multi-wire battery plug from the motherboard.
            Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
            Use a Phillips #0 screwdriver to remove the thirteen black 4 mm screws from the face of the motherboard.
            Use a Phillips #0 head screwdiver to remove the four silver 4 mm screws from the face of the motherboard
            Use a Phillips #0 head screwdriver to remove the one black 4 mm screw from the indented area above the fan.
            Use the precision tweezers to flip the black switch holding the film connected to the USB port.
            Gently remove the film from it's connection to the motherboard.
            Gently pull the thick wire in between the fan and the motherboard. To release the wire connected to the motherboard, gently pull towards the cooling fan.
            Gently pull the red, black, and white wire found on the top right-hand corner of the motherboard.
            Lift the black and white wires out of their ports at the top of the motherboard.
            Lift the top right corner of the motherboard to access the final wire.
            Gently remove the wire from the port connecting it to the motherboard.
            Remove the motherboard from the laptop.
Hello, I am interested in know how could I change the diode m51j, due to the volts from the USB don't function it, please could you help me, my email address is ing.gabriel.alcazar@gmail.com if you have the technical manual will be great
Thank you
This is also the same disassembly for upgrading the system memory. DDR3L PC3L-12800 1600MHz SODIMM, 16 GB max, 2 memory slots.
