Asus X550ZA-SA100603E Cooling Fan Replacement
  1. Asus X550ZA-SA100603E Cooling Fan Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the Phillips #0 screwdriver, remove the seven 14 mm screws on the bottom of the laptop.
    • Then use the Phillips #0 to remove the three 4 mm screws on the bottom of the laptop.
    Can I get a link to the replacement fan, please?
    Riley's Alias - crwdns2934203:0crwdne2934203:0
  2. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Insert a plastic opening tool between the keyboard and base of the laptop to pry the keyboard away from the base. Do this around the entire perimeter of the laptop.
    • This disconnects the face of the keyboard. Gently lift the keyboard up to expose the motherboard.
    • There are still ribbon cables connecting the keyboard face to the motherboard. Do not pull the keyboard away roughly.
  3. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Gently lift the keyboard to access the three ribbon cables connected to the motherboard
    • Using precision tweezers, flip up the white and black retaining flaps on the ZIF connectors that hold the two smaller ribbon cables in place.
    • Gently pull the ribbon cables from their sockets on the motherboard.
  4. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Push the two white clamps on the large ZIF connector towards the screen.
    • Gently remove the track pad ribbon cable from its connector.
  5. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the keyboard.
  6. Asus X550ZA-SA100603E Cooling Fan Replacement, Battery: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement, Battery: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the multi-wire battery plug from the motherboard.
  7. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Pull the two tabs holding the battery in place and lift the battery up. It should remove easily.
  8. Asus X550ZA-SA100603E Cooling Fan Replacement, Motherboard: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a Phillips #0 screwdriver to remove the thirteen black 4 mm screws from the face of the motherboard.
    • Use a Phillips #0 head screwdiver to remove the four silver 4 mm screws from the face of the motherboard
    • Use a Phillips #0 head screwdriver to remove the one black 4 mm screw from the indented area above the fan.
  9. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the precision tweezers to flip the black switch holding the film connected to the USB port.
    • Gently remove the film from it's connection to the motherboard.
  10. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the thick wire in between the fan and the motherboard. To release the wire connected to the motherboard, gently pull towards the cooling fan.
  11. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently pull the red, black, and white wire found on the top right-hand corner of the motherboard.
  12. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the black and white wires out of their ports at the top of the motherboard.
  13. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the top right corner of the motherboard to access the final wire.
    • Gently remove the wire from the port connecting it to the motherboard.
  14. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the motherboard from the laptop.
  15. Asus X550ZA-SA100603E Cooling Fan Replacement, Cooling Fan: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X550ZA-SA100603E Cooling Fan Replacement, Cooling Fan: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn the motherboard over so that the copper heat sink and fan pin connections are facing towards you.
  16. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Pull the red, black, and yellow wire from out of its connection port.
  17. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the four 4mm Phillips #0 screws that are binding the copper heat sink to the motherboard.
  18. Asus X550ZA-SA100603E Cooling Fan Replacement: crwdns2935265:018crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the fan assembly from the motherboard.
Tim Linton
crwdns2935283:004/06/17crwdne2935283:0
796 crwdns2915208:0crwdne2915208:0
Eastern Washington University, Team S1-G7, Crane Spring 2017 crwdns2935289:0Eastern Washington University, Team S1-G7, Crane Spring 2017crwdne2935289:0
EWU-CRANE-S17S1G7
Great guide. Do you have the part number for the cooling fan/heatsink assembly, and possibly where you can buy a replacement? I’ve only been able to find it on Ali Express, but they’re blocking US purchases.
Jay Marble - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,010
