ASUS X54C, X54H, X54L, X54HR - how to replace or upgrade HDD, RAM memory, Wi-Fi module.
crwdns2936621:0crwdne2936621:0
Disconnect the charger and switch off the laptop.
Two keys keep locked battery.
Remove the two Phillips screws.
Remove the HDD cover.
The HDD caddy iz secured by three Phillips screws. Remove them.
Use the black tape near to the SATA connector to slide and remove the HDD.
To remove the hard disk from the HDD caddy, unscrew the 2x Phillips screw.
There is one expansion slot for a memory module:
SO DIMM 204-pin, DDR3 SDRAM, 1333 MHz
Under the HDD cover is also the Wi-Fi card.
Bonjour,
Le Portable ASSUS X54C peut-il supporter 8Go de RAM alors qu’au départ, il en a 4 Go ?
merci pour le tuto.
CR (rousselclaude0995@orange.fr)
Bonjour, oui il peut aller jusqu'à 8Go maximum.
Brendan -
bonjour, un asus x54h peut il supporter 8go de ram ?
merci
Bonjour,
Oui il peut supporter 8 Go de RAM maximum.
Brendan -
