Asus X540S panel Disassembly
    • Open the Optical Drive to allow removal of keyboard before powering down computer.
  1. Asus X540S panel Disassembly: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the two 15mm Philips #1 screws.
    • Remove the two 12mm Philips #1 screws.
    • Remove the six 9mm Philips #1 screws.
  2. Asus X540S panel Disassembly: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X540S panel Disassembly: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X540S panel Disassembly: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the side of the top.
    • Remove the keyboard cable.
    • Remove the trackpad cable.
    • Lift the release tabs on the keyboard/trackpad connectors
    When removing both cables there is a small black plastic flap covering the connection.
    GENTLY lift that flap and GENTLY lift the end of the cable/ribbon and you're good to go.
    My first try I was under the impression it was more of a plug and didn't see any specifics just like above “remove cable” but no description of how.
    Even though I did it wrong, it didn't damage anything, and this guide was a big help.
    F S - crwdns2934203:0crwdne2934203:0
    Added a note. Thanks for the comment!
    Padraic Hoselton -
    While lifting the lid, it's useful to have a spudger to detach the snaps from the top
    Emily Klassen - crwdns2934203:0crwdne2934203:0
crwdns2935229:014crwdne2935229:0
Padraic Hoselton
crwdns2935283:008/22/17crwdne2935283:0
4.339 crwdns2915208:0crwdne2915208:0
Apple tech crwdns2935289:0Apple techcrwdne2935289:0
Community
crwdns2935297:020crwdne2935297:0
Feels like the panel is glued on mine. all screws are out, corners are loose but rest feels glued. anybody have advice? I dont have access to a heatgun
Non Gerrell - crwdns2934203:0crwdne2934203:0
Well the first time I did it I had to give it a bit more pressure and loosen it up on all the sides. Because it should only be snapped in place. I don’t remember mine having glue the first time but I do remember I needed pry tools to get it off. I used some ifixit spudgers.
Padraic Hoselton -
I used a plastic card (like credit card) to slide between the panels along the edge - it went smooth!
Alexey Sazonov -
Le mien à subit un Court circuit comment faire pour le réparer
Merus Schadrack Djefly - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 37
crwdns2942667:0crwdne2942667:0 10,782
