In this guide I will be showing you how to replace the SSD in your ASUS X515.
Power down the laptop and unplug all of the cables.
Flip over the laptop.
Remove the 10 phillips screws from the bottom of the case.
Using a prying tool pry the bottom of the case open.
Locate the battery and its connector.
Using your fingers or a prying tool pull up on the connector to disconnect it.
Locate the SSD
Peel the tape so that you can access the screw.
Remove the single screw.
The SSD will pop up and face outwards.
Pull the SSD outwards.
