Asus X502CA-BCL0901D Webcam Replacement
  1. Asus X502CA-BCL0901D Webcam Replacement, Screen Frame: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X502CA-BCL0901D Webcam Replacement, Screen Frame: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
  2. Asus X502CA-BCL0901D Webcam Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
    • The screws are 20 mm in diameter and 50 mm long.
  3. Asus X502CA-BCL0901D Webcam Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using the plastic opening tool, pry the screen frame away from the screen.
  4. Asus X502CA-BCL0901D Webcam Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using your hands, grasp the screen frame at it's base near the laptop hinge.
    • While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
    • The space between the screen frame and laptop hinge is very small and the plastic for both parts is weak. However, a fair amount of force is required to disconnect the screen frame from the laptop hinge. Be careful during this step, or either of these plastic pieces may break.
  5. Asus X502CA-BCL0901D Webcam Replacement, Webcam: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using tweezers, unplug the webcam wire from the webcam.
    • If this wire was already disconnected, that may be the cause of the webcam not functioning. Try reconnecting this wire and reassembling to see if the problem is resolved before continuing.
  6. Asus X502CA-BCL0901D Webcam Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Using fingers or tweezers, pry the webcam from the laptop.
    • The webcam is only secured with adhesive.
Gregory Browne
crwdns2935283:010/19/17crwdne2935283:0
501 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G5, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G5, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G5
crwdns2942667:0crwdne2942667:0 574
