If you need to replace any portion of the upper part of your laptop: screen, webcam, etc. then you need to remove the screen frame first. This guide will show you how to do that.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
Using the tweezers, remove the 2 black plastic adhesive covers from the bottom corners of the screen frame.
Use the Philips #00 screwdriver to remove the 2 screws that were revealed in the previous step.
Using the plastic opening tool, pry the screen frame away from the screen.
Using your hands, grasp the screen frame at it's base near the laptop hinge.
While pulling the base of the screen frame away from the hinge horizontally, also lift up on the screen frame to disconnect it from the laptop hinge.
