The keyboard, track pad, and palm rest are all part of the same assembly, if you need to replace any one of these items you will need to replace the whole assembly. This guide will show you how to do that.
Flip the laptop over so that it is upside down.
Remove the 11 screws from the bottom of the laptop with the Phillips #00 screwdriver.
Use the Plastic Opening Tool to pry the keyboard assembly away from the rest of the laptop.
crwdns2935267:0crwdne2935267:0Tweezers$4.99
While lifting the keyboard assembly, use the tweezers to gently remove the keyboard cable and the touch pad cable by pulling the wires away from the laptop base. Both cables must be gently but firmly pulled towards you for safe removal.
Lift the keyboard assembly away from the remainder of the laptop.
