Asus X501A-RH31 Keyboard Replacement
    1. Asus X501A-RH31 Keyboard  Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the laptop over so that the back is facing upwards.
    2. Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • To unlock the left tab, make sure the tab on the left has red showing.
    3. Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • To unlock the right tab, push the right slider to the left with one hand.
      • Push the battery out with the other hand.
    1. Asus X501A-RH31 Keyboard  Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X501A-RH31 Keyboard  Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
      • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
    2. Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Turn the laptop over and open the top so the keyboard is facing you.
    3. Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
      • Pry off the keyboard cover on the edge using the plastic opening tool.
      • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
      • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
    4. Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Slowly lift the keyboard upward, but do not remove completely.
      • Remove the two data cables that attach the keyboard to the motherboard.
    5. Asus X501A-RH31 Keyboard  Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
      • Use tweezers to pull the white plastic piece up that is attached to the data cable.
      • Repeat this process for the big black cable as well.
      • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
Romana Hruby
crwdns2935283:010/20/17crwdne2935283:0
596 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G3, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G3
crwdns2935297:056crwdne2935297:0
crwdns2942667:0crwdne2942667:0 1,561
