Asus X501A-RH31 Fan Replacement
  1. Asus X501A-RH31 Fan Replacement, Battery: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over so that the back is facing upwards.
  2. Asus X501A-RH31 Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • To unlock the left tab, make sure the tab on the left has red showing.
  3. Asus X501A-RH31 Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X501A-RH31 Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • To unlock the right tab, push the right slider to the left with one hand.
    • Push the battery out with the other hand.
  4. Asus X501A-RH31 Fan Replacement, Keyboard: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X501A-RH31 Fan Replacement, Keyboard: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Using the Phillips #00 screwdriver unscrew all nine screws from the bottom of the laptop, as well as the additional two screws inside the battery compartment.
    • Nine of the screws are 5 mm long, 4.5 mm in diameter, while two screws closest to the hinges are 7 mm long.
  5. Asus X501A-RH31 Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Turn the laptop over and open the top so the keyboard is facing you.
  6. Asus X501A-RH31 Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X501A-RH31 Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Pry off the keyboard cover on the edge using the plastic opening tool.
    • Start from one side. Once it is lose, carry out the same procedure on the front and other side.
    • Only do little sections at a time as the keyboard may break if you attempt to take the whole thing off from a single point.
  7. Asus X501A-RH31 Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slowly lift the keyboard upward, but do not remove completely.
    • Remove the two data cables that attach the keyboard to the motherboard.
  8. Asus X501A-RH31 Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use tweezers to pull the white plastic piece up that is attached to the data cable.
    • Repeat this process for the big black cable as well.
    • Use caution when unlatching the data cables from the motherboard. The cables are extremely delicate and can break.
  9. Asus X501A-RH31 Fan Replacement, Fan: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three screws using the Phillips #00 screwdriver.
    • The three screws are 5 mm in length, 4.2 mm in diameter.
  10. Asus X501A-RH31 Fan Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the three screws on the left hand side of the big motherboard.
    • This will loosen the motherboard, which will allow for better access to the cables in the next step.
    • The three screws are 5 mm in length, 4.2 mm in diameter and Phillips head screws.
  11. Asus X501A-RH31 Fan Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X501A-RH31 Fan Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X501A-RH31 Fan Replacement: crwdns2935265:011crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the connector cable attached to the bottom of the motherboard.
    • Take the black plastic spudger and press down on the lower half of the white plastic piece to remove the connector cable.
Christopher
crwdns2935283:010/19/17crwdne2935283:0
371 crwdns2915208:0crwdne2915208:0
UMass Dartmouth, Team S3-G3, Bailey Fall 2017 crwdns2935289:0UMass Dartmouth, Team S3-G3, Bailey Fall 2017crwdne2935289:0
UMASSD-BAILEY-F17S3G3
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 615
