Asus X401A Processor Replacement
  1. Asus X401A Processor Replacement, Processor: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Processor Replacement, Processor: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your laptop off and unplug it from its charger prior to the repair to avoid electric shock.
    • Turn your laptop over, and press on the latches to remove the battery.
  2. Asus X401A Processor Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Unscrew the ten screws with a Phillips Head #1 screwdriver.
    • Eight screws are 3mm.
    • Two screws are 4mm.
    • Place the screws on a magnetic mat.
  3. Asus X401A Processor Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Separate the keyboard from the back of the laptop with a plastic opening tool.
    • Do not completely separate the two pieces as there are ribbon cables that need to be disconnected.
    • When reassembling, you will hear snapping noises as the pieces connect together.
  4. Asus X401A Processor Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift ZIF tabs up to disconnect the black and the white ribbon cable.
  5. Asus X401A Processor Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Unscrew the ten 3mm screws with a Phillips Head #1 screwdriver,
  6. Asus X401A Processor Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a spudger to lift the ZIF connector up to release the ribbon cable.
  7. Asus X401A Processor Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Lift the connection between the screen and motherboard with a plastic spudger.
    • Remove the yellow and the clear tape.
  8. Asus X401A Processor Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Disconnect the wire connecting the speakers.
  9. Asus X401A Processor Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:09crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:09crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Lift the motherboard from the frame with a plastic spudger.
    • Set the frame of the laptop aside, and turn the motherboard over.
  10. Asus X401A Processor Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:010crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Unscrew the four screws with a Phillips Head #1 screwdriver to disconnect the fan from the processor.
  11. Asus X401A Processor Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Disconnect the cable connecting the fan to the motherboard.
    • Lift the fan part from the processor.
  12. Asus X401A Processor Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Processor Replacement: crwdns2935265:012crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Unscrew the screw holding the processor to the motherboard with a flathead screwdriver.
    • Lift the processor up away from the socket.
Tyler Stiles
crwdns2935283:002/07/17crwdne2935283:0
152 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-4, Wilder Spring 2017 crwdns2935289:0Ohio State, Team 1-4, Wilder Spring 2017crwdne2935289:0
OSU-WILDER-S17S1G4
Hi
What is the highest CPU I can put on it?
Does Asus X401A support i5-2450M?
mmaksat1988 - crwdns2934203:0crwdne2934203:0
crwdns2942667:0crwdne2942667:0 2,047
