Asus X401A Internal Fan Replacement
  1. Asus X401A Internal Fan Replacement, Internal Fan: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip over the laptop and remove the battery for ease of replacement.
  2. Asus X401A Internal Fan Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    Magnetic Project Mat
    $19.95
    • Remove the screws located underneath the laptop by using a Phillips #00 screwdriver. This will assist you when disconnecting the keyboard cover from the rest of the laptop.
    • Remove the two 4mm screws.
    • Place the screws on a magnetic mat to not lose them.
  3. Asus X401A Internal Fan Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip the laptop back over and begin prying the keyboard cover from the rest of the laptop by using a plastic spudger.
    • The keyboard is still attached to the motherboard via two ribbon cables. Do not pull the keyboard away from the laptop.
  4. Asus X401A Internal Fan Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use a spudger to lift the ZIF tabs.
    • Remove both the black and white ribbon cables in order to completely detach the cover from the rest of the device.
  5. Asus X401A Internal Fan Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove all screws that connect the motherboard to the bottom of the laptop.
    • The motherboard holds the internal fan in place
    • Before attempting to remove the motherboard, be sure to disconnect both sets of wires as pictured.
  6. Asus X401A Internal Fan Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Once all screws are removed and both sets of wires are detached, use a spudger to carefully pry up the motherboard along with the attached internal fan.
    • Set the rest of the laptop aside and direct your attention to only the motherboard.
  7. Asus X401A Internal Fan Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:07crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Flip the motherboard over and you will notice four screws (circled in yellow) that are connecting the fan's bracket to the motherboard. Using your screwdriver, remove the four screws and place them off to the side.
  8. Asus X401A Internal Fan Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus X401A Internal Fan Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • One final group of wiring will also be connecting the internal fan to the motherboard. Careful disconnect it as shown.
    • With the internal fan completely disconnected from the motherboard, you should be able to freely remove it.
    • Replace the faulty internal fan with a new one and repeat the previous steps for reassembly.
Skylar Alexander
crwdns2935283:002/07/17crwdne2935283:0
137 crwdns2915208:0crwdne2915208:0
Ohio State, Team 1-4, Wilder Spring 2017 crwdns2935289:0Ohio State, Team 1-4, Wilder Spring 2017crwdne2935289:0
OSU-WILDER-S17S1G4
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 878
