Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Take two rubber caps off the back side of the laptop.
Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Look at comments in the previous step. There are 2 more screws.
Take gold cap that connects to a black wire off using the metal spudger.
Remove the following two screws:
Two 4 mm screws using Phillips #0 screwdriver.
Slide the component up and out.
Hi, i want to add bluetooth modul on my x200ma, but bluetooth dongle doesn look prety good and not portable enough if we always plug it into usb port, so can we change wifi modul on this model with another modul that say 2in1 wifi+bluetooth?
If it work, which type modul i can use?
Thank you. Sorry my bad english.
There are also two other screws under the rubber feet above the battery.
digg1024 - crwdns2934203:0crwdne2934203:0
I agree. Two another 14 mm screws under the rubber feet.
shao.onii - crwdns2934203:0crwdne2934203:0
