Asus X200MA Wireless Card Replacement
  1. Asus X200MA Wireless Card Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
    There are also two other screws under the rubber feet above the battery.
    digg1024 - crwdns2934203:0crwdne2934203:0
    I agree. Two another 14 mm screws under the rubber feet.
    shao.onii - crwdns2934203:0crwdne2934203:0
  2. Asus X200MA Wireless Card Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Wireless Card Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
    Clément Marshall - crwdns2934203:0crwdne2934203:0
    Look at comments in the previous step. There are 2 more screws.
    Károly Varga - crwdns2934203:0crwdne2934203:0
  4. Asus X200MA Wireless Card Replacement, Wireless Card: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take gold cap that connects to a black wire off using the metal spudger.
  5. Asus X200MA Wireless Card Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following two screws:
    • Two 4 mm screws using Phillips #0 screwdriver.
  6. Asus X200MA Wireless Card Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the component up and out.
    Hi, i want to add bluetooth modul on my x200ma, but bluetooth dongle doesn look prety good and not portable enough if we always plug it into usb port, so can we change wifi modul on this model with another modul that say 2in1 wifi+bluetooth?
    If it work, which type modul i can use?
    Thank you. Sorry my bad english.
    Yudha Mobile - crwdns2934203:0crwdne2934203:0
Vanessa Garcia
crwdns2935283:001/22/15crwdne2935283:0
1,796 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-24, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 21-24, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S21G24
crwdns2942667:0crwdne2942667:0 4,130
