Asus X200MA Hard Drive Replacement
  1. Asus X200MA Hard Drive Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
    There are also two other screws under the rubber feet above the battery.
    digg1024 - crwdns2934203:0crwdne2934203:0
    I agree. Two another 14 mm screws under the rubber feet.
    shao.onii - crwdns2934203:0crwdne2934203:0
  2. Asus X200MA Hard Drive Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
    Clément Marshall - crwdns2934203:0crwdne2934203:0
    Look at comments in the previous step. There are 2 more screws.
    Károly Varga - crwdns2934203:0crwdne2934203:0
  4. Asus X200MA Hard Drive Replacement, Hard Drive: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the black foam and adhesive located on top of the hard drive.
  5. Asus X200MA Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  6. Asus X200MA Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide out the hard drive
    Slide the drive to the right, away from the sata connectors at the left.
    There are also screws under the rubber feet on the battery well.
    retail - crwdns2934203:0crwdne2934203:0
Vanessa Garcia
crwdns2935283:001/22/15crwdne2935283:0
1,796 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-24, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 21-24, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S21G24
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - crwdns2934203:0crwdne2934203:0
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 9,510
