Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Take two rubber caps off the back side of the laptop.
Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Look at comments in the previous step. There are 2 more screws.
Remove the black foam and adhesive located on top of the hard drive.
Remove the following four screws:
Four 4 mm Phillips #0 using a phillips screwdriver.
Slide out the hard drive
Slide the drive to the right, away from the sata connectors at the left.
There are also screws under the rubber feet on the battery well.
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
There are also two other screws under the rubber feet above the battery.
digg1024 - crwdns2934203:0crwdne2934203:0
I agree. Two another 14 mm screws under the rubber feet.
shao.onii - crwdns2934203:0crwdne2934203:0
