If your battery is giving you a hard time on your laptop, follow this guide.
Remove the following six screws:
Six 4 mm screws using a Phillips #0 screwdriver.
Remove the following one screw:
One 14 mm screw using a Phillips #0 screwdriver.
Take two rubber caps off the back side of the laptop.
Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
Look at comments in the previous step. There are 2 more screws.
Remove the following two screws under the rubber caps.
Two 14 mm screws using the Phillips #0 screw driver.
Flip up the following:
The two latches holding the two cables shown(white and black)
Pull the cables free from the latches
Lift the keyboard from the computer
Remove the following screws from the inside of the laptop:
Two 4 mm screws using the Phillips #0 phillips screwdriver.
One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
crwdns2935229:030crwdne2935229:0
crwdns2947412:08crwdne2947412:0
Merci super!
Thanks for the write up! Easy to follow, Great photos, and worked great!
thanks it worked
Your step by step instructions were so easy to follow. Great job. Thanks! :)
I would like to buy a battery to it, Please suggest me the best portal site
Worked like a charm — Thank you!!!!
My 8-year-old and I completed this together in about 20 minutes. Very straightforward.
Absolutely fantastic instructions! Easy peasy with your directions and illustrations! Perfect for non-techie amateurs like us! Thank you, thank you, thank you! ⭐⭐⭐⭐⭐
There are also two other screws under the rubber feet above the battery.
digg1024 - crwdns2934203:0crwdne2934203:0
I agree. Two another 14 mm screws under the rubber feet.
shao.onii - crwdns2934203:0crwdne2934203:0
