Asus X200MA Battery Replacement
  1. Asus X200MA Battery Replacement, Back Panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
    There are also two other screws under the rubber feet above the battery.
    digg1024 - crwdns2934203:0crwdne2934203:0
    I agree. Two another 14 mm screws under the rubber feet.
    shao.onii - crwdns2934203:0crwdne2934203:0
  2. Asus X200MA Battery Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
    How exactly does the keyboard pod out ? It doesn’t come off at the screen hinge.
    Clément Marshall - crwdns2934203:0crwdne2934203:0
    Look at comments in the previous step. There are 2 more screws.
    Károly Varga - crwdns2934203:0crwdne2934203:0
  4. Asus X200MA Battery Replacement, Battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
  5. Asus X200MA Battery Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Slide the battery up and out.
crwdns2935229:030crwdne2935229:0
Vanessa Garcia
crwdns2935283:001/22/15crwdne2935283:0
1 796 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 21-24, Maness Winter 2015 crwdns2935289:0Cal Poly, Team 21-24, Maness Winter 2015crwdne2935289:0
CPSU-MANESS-W15S21G24
crwdns2947412:08crwdne2947412:0
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - crwdns2934203:0crwdne2934203:0
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - crwdns2934203:0crwdne2934203:0
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - crwdns2934203:0crwdne2934203:0
Worked like a charm — Thank you!!!!
mpoinsetta - crwdns2934203:0crwdne2934203:0
My 8-year-old and I completed this together in about 20 minutes. Very straightforward.
Michael Richardson - crwdns2934203:0crwdne2934203:0
Absolutely fantastic instructions! Easy peasy with your directions and illustrations! Perfect for non-techie amateurs like us! Thank you, thank you, thank you! ⭐⭐⭐⭐⭐
Debi S - crwdns2934203:0crwdne2934203:0
crwdns2936753:030crwdne2936753:0 44
crwdns2942667:0crwdne2942667:0 36,212
