This guide will show you how to replace the battery of the Asus X200CA. The battery is a 3Cells 3300 mAh 33 Whrs.
Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
Remove the black 14.5mm screw from the center of the bottom cover.
Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
Pull apart the keyboard and the bottom cover using your hands.
Use a Phillips #00 screwdriver to remove the black 4.7mm screw holding the battery in place.
Lift the battery by the tab you removed the screw from.
Replace with the new battery, if necessary.
crwdns2935229:011crwdne2935229:0
