Asus W2W-A1 Keyboard Replacement
  1. Asus W2W-A1 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus W2W-A1 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus W2W-A1 Keyboard Replacement, Keyboard: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the battery, then unscrew the 7 3 mm Phillips screws behind the battery. Make sure they go in separate, organized piles.
    • Unscrew the 2 4 mm Phillips head screws by the battery.
  2. Asus W2W-A1 Keyboard Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Remove the panel above the keyboard with a plastic spudger.
  3. Asus W2W-A1 Keyboard Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Once the panel is removed, use the spudger to pry out the keyboard.
    • Do not fully remove, for the keyboard is still attached to the ribbon cable.
  4. Asus W2W-A1 Keyboard Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus W2W-A1 Keyboard Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Detach the ribbon cable from the keyboard by pulling the end of the ribbon cable that is attached inside of the laptop.
    • Be sure to detach from the root rather than from near the middle. It should slide out with ease.
    • Now you can fully remove the keyboard from the laptop.
Joe Redfearn
crwdns2935283:004/14/14crwdne2935283:0
97 crwdns2915208:0crwdne2915208:0
Cal Poly, Team 13-29, Maness Spring 2014 crwdns2935289:0Cal Poly, Team 13-29, Maness Spring 2014crwdne2935289:0
CPSU-MANESS-S14S13G29
crwdns2936753:030crwdne2936753:0 7
crwdns2942667:0crwdne2942667:0 317
