This guide will explain how to replace the back cover of this device.
Flip the device over so that the back cover is facing you.
Remove the four 5mm Phillips #1 screws from the top of the laptop.
Remove the two 6mm Phillips #1 screws from the sides of the laptop.
Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
Its not phisically possible if i will try harder the laptop will break in half
Lift off the cover and remove the back cover from the device.
thank you. this guide was a hugh help to me.
