A battery is an essential part of the laptop which is needed in order to power on and use the computer. This guide will show you how to replace the battery of your Asus Vivobook Max X541SA-PD0703X. In order to replace the battery, you will have to remove the hard drive, motherboard, wifi card, and disc drive insert.
Flip the laptop upside down so that the back of the laptop faces you.
Remove the following ten Phillips #0 screws from the bottom of the laptop:
Six 13mm screws.
Four 11mm screws.
Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
Pull the ribbon cables out of their sockets.
Remove the three 6mm Phillips #0 screws from the motherboard.
Pull the Wi-Fi card out of the motherboard.
The removal of the wifi card seems unnecessary for removing the hard drive.
Remove the hard drive by pulling it towards the right, and removing it from the laptop case
I have an ASUS x451N. I changed the storage to an ssd since its very slow and now it doesn't boot. It just gets stuck in bios. It appears in the storage section but not on the boot menu. The ssd has an os and I have already tried to boot it in my pc and it works. I hope you can help me with this problem. Thank you!
Christusjohn Leoncio L Salvani - crwdns2934203:0crwdne2934203:0
Remove the disc drive by sliding it towards the right and removing it from the laptop case
Remove the three 6mm Phillips #0 screws from the fan shroud.
Remove the shroud from the motherboard.
There is a wire attached to the screen display.
Peel the sticker and disconnect it from the motherboard.
Remove the plastic covering off of the motherboard.
Remove the five 6mm Phillips #0 screws from the motherboard.
Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
Pull the motherboard to the right and lift up.
Remove the 6mm Phillips #0 screw from the battery bracket.
Use a plastic opening tool to remove the battery from the laptop.
Finished so simple, guide was easy to follow. Thank you
Who was the idiot who designed this laptop? Remove the motherboard to replace the battery? Unbelievable.
I have a dead cmos battery and it seems i need to replace the whole battery
Sir how do I replace my cmos battery? Is it integrated with the battery. I also have Asus Vivobook Max X541SA-PD0703X
