Asus Vivobook F510UA Hard Drive Replacement
  1. Asus Vivobook F510UA Hard Drive Replacement, Removing the bottom panel: crwdns2935265:01crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement, Removing the bottom panel: crwdns2935265:01crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Turn your laptop so that the back panel is facing you.
    • Remove the large gray rubber pads.
    • Remove twelve screws from the bottom of the laptop using a Phillips #0 screwdriver.
    • There are four different screw sizes.
  2. Asus Vivobook F510UA Hard Drive Replacement, Screws under the rubber feet: crwdns2935265:02crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement, Screws under the rubber feet: crwdns2935265:02crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the screws from beneath the rubber pads using a Phillips #0 screwdriver.
  3. Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:03crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    iFixit Opening Tool
    $1.99
  4. Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement, Disconnect the battery: crwdns2935265:04crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • For precautionary purposes, we advise that you disconnect the battery connector to avoid any electrical discharge.
    • Use plastic tools to avoid damaging the battery, which could leak dangerous chemicals or catch fire.
    • Using a fingernail or spudger, move back the retaining clip holding the battery connector in place.
    • The battery connector is very fragile. Proceed with caution.
    • Put a spudger under the battery connector and twist, to lift off the connector.
    • You may want to look at the battery disconnection steps for Asus Vivobook F412DA: Release battery connector, which are the same as for this model.
  5. Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:05crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the four screws from the hard drive using a Phillips #0 screwdriver.
    • Peel off the tape covering the end of the hard drive to reveal additional screws.
  6. Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus Vivobook F510UA Hard Drive Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Hold the base of the hard drive tray and slide it out and away from its connector.
    • Remove the four Phillips #0 screws from the hard drive tray to free the drive.
    • Install the new drive into the tray, then slide the tray back into the laptop.
    • After inserting your new SSD, apply the thermal pad on top of the area where the connector is.
Deandre Mendes
crwdns2935283:001/13/22crwdne2935283:0
171 crwdns2915208:0crwdne2915208:0
York University, Team S-17, Woodhouse Winter 2022 crwdns2935289:0York University, Team S-17, Woodhouse Winter 2022crwdne2935289:0
YORK-WOODHOUSE-W22SSG17
Usually, the battery is disconnected before working on the internals of the laptop. While the battery itself is a different model, the instructions for removing the battery connector in Asus VivoBook 14-Inch F412DA Battery Replacement#Release the battery connector worked well for this laptop.
Sohum - crwdns2934203:0crwdne2934203:0
crwdns2936753:07crwdne2936753:0 18
crwdns2936753:030crwdne2936753:0 48
crwdns2942667:0crwdne2942667:0 1,937
