Asus VivoTab RT TF600T Screen charging port Replacement
  1. Asus VivoTab RT TF600T Screen charging port Replacement, Screen charging port: crwdns2935265:01crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement, Screen charging port: crwdns2935265:01crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement, Screen charging port: crwdns2935265:01crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Make sure the tablet is turned off.
    • Remove the tablet from the attached keyboard.
    • To remove the keyboard, simply depress the switch on the left side of the screen and pull the tablet portion off.
  2. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:02crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:02crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:02crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Rotate the device 180°, and remove the two 1.59 mm screws at the bottom of the device.
    • Use the Phillips screwdriver size PH000 to remove the two 1.59 mm screws.
  3. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:03crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:03crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Use the plastic opening tool to help detach the screen from the back panel.
    • Insert the plastic opening tool into the bottom right corner and gently start to pry off the screen.
    • Once the screen begins to separate from the body of the device, start working the tool around the outer edges until the entire screen becomes detached.
  4. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:04crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:04crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Now that the screen is completely detached, lay the back panel flat on a smooth surface.
    • Lift the screen to view the inside of the tablet.
  5. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:05crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:05crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Before disconnecting the display cables, turn off the switch labeled DIP; this switch is used to de-energize the system.
    • The battery is connected to the motherboard. To avoid any short circuiting of the device, you must place the switch labeled DIP to OFF.
  6. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:06crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:06crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:06crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Remove the yellow tape covering the end of the cables.
  7. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:07crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:07crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • After lifting the yellow tape, you should be able to see a white strip. The white strip is actually a lever.
    • Use the plastic opening tool to push in the levers.
  8. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:08crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:08crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:08crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • With all three white levers pushed in, gently pull on each display cable until the cable disconnects.
  9. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:09crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Lift the screen upwards to remove.
  10. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:010crwdnd2935265:01crwdnd2935265:01crwdne2935265:0
    • Rotate the tablet clockwise, so the charging port is turned towards you.
    • Remove the two 0.79 mm #00 screws from the charging port with the Philips #00 Screwdriver.
  11. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:011crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:011crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Place the plastic opening tool behind the charging port, closest to the outer edge of the device.
    • Gently pry the charging port away from the frame.
  12. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:012crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:012crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the eleven 0.79 mm #000 screws around the motherboard with the Phillips #000 screwdriver.
  13. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:013crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:013crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:013crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon or metal spudger to help pry the motherboard from the back panel.
    • Once the mother board is relieved from the glue, use your hand to lift the motherboard up and to the opposite end of the back panel.
  14. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:014crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:014crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Flip up the white lever with the plastic opening tool to release the connection.
  15. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:015crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:015crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Gently remove the charging port ribbon piece from the motherboard. It should come out easily using your fingers.
  16. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:016crwdnd2935265:01crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:016crwdnd2935265:02crwdnd2935265:03crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:016crwdnd2935265:03crwdnd2935265:03crwdne2935265:0
    • Use the nylon or metal spudger to pry the battery from the back panel.
    • Flip the right side of the battery up to expose the charging port cable.
  17. Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:017crwdnd2935265:01crwdnd2935265:02crwdne2935265:0 Asus VivoTab RT TF600T Screen charging port Replacement: crwdns2935265:017crwdnd2935265:02crwdnd2935265:02crwdne2935265:0
    • Remove the charging port and replace it.
Joseph C Reneau
crwdns2935283:010/15/15crwdne2935283:0
276 crwdns2915208:0crwdne2915208:0
Sam Houston State, Team 1-2, Blackburne Fall 2015 crwdns2935289:0Sam Houston State, Team 1-2, Blackburne Fall 2015crwdne2935289:0
SHSU-BLACKBURNE-F15S1G2
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 2,287
